noise while turning after steering wheel install *SOLVED*
Posted: September 13th, 2008, 8:37 pm
by eyezpinned
i just put a momo steering wheel in my car, but now i'm getting this noise when i turn the wheel. sounds kinda like if you were to wet your tires and then turn the wheel while the car was stationary. almost like a rubber, squeeky cartoon shoe leather type of noise. i greased up everything that needed to be greased (i think). any ideas?
Re: noise while turning after steering wheel install
Posted: September 13th, 2008, 10:57 pm
by solo_ryder
X2
i am having a similar issue. I think it has something to do with your wheel hub personally..
Mine on the other hand I am not sure as it is a straight bolt on..kinda... but I have not looked into it to much
Posted: September 14th, 2008, 5:39 am
by eyezpinned
well as long as im not the only one lol... im gonna pop off the ignition cover plastic today to see what that turns up (lost daylight yesterday)...
Re: noise while turning after steering wheel install *SOLVED*
Posted: September 14th, 2008, 1:26 pm
by eyezpinned
i figured it out... on the stock hub there is a plastic ring with two tabs across from eachother (has to do with the turn signal return i think)... if when yo put a hub adapter, or any other wheel for that matter, you have to make sure these tabs pop into the adapter/wheel. the noise was the plastic ring rubbing. once it is secured it stops making noise.
