sold
Re: (fs) Fidanza flywheel & Centerforce df clutch/pressure plate
In case you are new, if you buy this flywheel, more than likely you should also buy a new surface... which would cost about $68...
- 2fazed
Yes, having the flywheel resurfaced, costs here about $40.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
pm sent... I was interested in the flywheel...
EDIT:
unfortunately after I sent the PM, 2fazed changed his mind and wanted to sell both items together which is fine it would just help if I had known that beforehand before I got monies together, planning, etc.
EDIT:
- tehbrookzorz
You can resurface the exchangeable surfaces from Fidanza flywheels? Is that suggested?
Cody
- 2fazed
it's suggested in all flywheels to have them resurfaced before installing. It's to extend the lifetime in the flywheel.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
or to allow the clutch to "grab" it better, right?2fazed wrote:it's suggested in all flywheels to have them resurfaced before installing. It's to extend the lifetime in the flywheel.
