2 10" kickers 2000watts
Car Stereo/Alarm Discussions
Saku
Post by Saku »
So i'm getting 2 10" kickers 2000 watts and an 800 watt amp for 250
MX3-Life
Re: 2 10" kickers 2000watts
Post by MX3-Life »
Are those the Kicker CVX?
And i recommend a ported box even tho alot of people say kicker are best in non-ported.
Saku
Post by Saku »
this will sound really noobish of me cuss it is my first car but what is a ported...
they can in a box XD
MX3-Life
Post by MX3-Life »
Don't worry I once said the same thing
2 Main types of Boxes (That i know of)
Ported and Non-Ported (There are always different types of ports)
Ported
http://www.futureshop.ca/multimedia/pro ... 076989.jpg" onclick="window.open(this.href);return false;
Non-Ported
http://www.futureshop.ca/multimedia/pro ... 061592.jpg" onclick="window.open(this.href);return false;
Basically a "Port" is a hole in the box designed to enhance the sound of the bass and many other things like frequencies and other stuff, Just ask around and you'll find out tons of different opinions.
tmac4t4
Post by tmac4t4 »
ported boxes tend to give off better low frequencies where a sealed box would give you more punch..since they're 10's and you have 2, i'd say use a sealed box..would give off so much punch it would hurt :D :D ...whether or not to go with sealed or ported also depends on the application..with my old car i had 2 12's with a ported box, it was only ported because i had a trunk, rather than a hatchback..i had made the box myself and tried first without the ports, and then with...with a ported box in a trunk style car, the airwaves are able to travel out of the box and basicaly turn your trunk into a bigger sized speeker box. hope this helps you out a bit.
oh and i recommend checking out the manufacturer specs on the subs, they usually specify whether the speeker should be in a sealed/ported box..and if the box isnt the correct dimension as to what the speeker was designed for, it could sound like crap or worse you could blow your new investment
Return to “Car Stereo/Alarm”
