Clutch engages at different positions of the pedal, why?
Posted: June 9th, 2008, 8:20 pm
Hello guys,
Something weird is going on with my clutch. I started the car with the clutch pedal pushed in all the way and in reverse. When I released the clutch pedal, instead of engaging at about 70% released, the clutch engaged immediately! so I pushed it back in. I tried releasing the pedal again and did the same thing. I tried putting it in first gear and now when I pushed the pedal in the clutch wouldn’t disengage, so I turned the engine off. I pushed the clutch pedal all the way a couple of times and then started the car, now it was working like it normally does.
Today the same thing happened, and I noticed that if I have the car in gear, let’s say first or reverse, and I have to push and release the clutch pedal a couple of times while in gear, the position at which the clutch engages changes, from 70% released to about 10% (barely releasing the pedal).
What’s going on guys?
When I bought the car 8 months ago (about 6000 miles ago), I had the master and slave cylinders replaced, they are basically new!
Please help me out
Please help me out
