Well the time has come again and I'm looking at upgrading. I want to sell this turbo and move on to something a bit larger.
I will sell it in a variety of ways, or part it if no one is interested. Here's the specs:
Holset HY35, EXCELLENT condition, <25k miles (I got it with 10k). No shaft play, no damage whatsoever. This turbo is very similar in size to a Garrett 60-1, and is not some cheap knock off. They can take upwards of 30 psi reliably. Spins PERFECT, better than any non ball bearing turbo I have ever spun. This turbo means business.
Internal wastegate
bar/plate FMIC
2.5" mandrel collector with 1.75" primaries, bolts to stock K8 logs
2.5" mandrel intercooler pipes, 2.5" couplings with t bolt clamps
-4AN braided oil feed with all fittings to bolt right into your block
2.5" downpipe, bolts to stock cat
I made 403 whp 412 ft lbs of torque on this turbo with a 2.5" crush bent exhaust. That was on 16 psi with a horrible tune and pump gas. This kit is easily capable of 450 whp, and spools VERY fast considering the size. Simply hauls a--, however now I am building a motor and want to go bigger.
At this point I would like to get what I have into materials back out of it. That would be $1300. The quality of this kit is great, never has given me any problems. I can also include a nice formed metal oil drain and tapped oil pan to go with it, if necessary.
