Hesitation/Stumbling problem with B6 SOHC
Posted: February 23rd, 2008, 5:45 pm
I can feel the car stumbling under the following conditions:
- Engine has been fully warmed up
- RPM is between 1,200 and 3,300
- Any gear is engaged
- Gas pedal is depressed
In the past few months, I have replaced the following on the car:
- Fuel filter
- Fuel pump
- Timing belt
- Spark plugs
- Thermostat
- Coolant
- Oil and filter
- Muffler
- Cataylic converter
The only possbilities I can think of right now are either a blockage or clog in the fuel line somewhere, or the more dreaded cylinder crack. I somehow doubt the cylinder crack, as I hear zero knocking from the engine. Anyone have any ideas?
To expand a bit: No codes have been present at all, before and after the ECU reset, which was performed two weeks ago.
The problem began when there was a nice hole the size of my fist in the muffler about 1.5 months back. In addition, the car had been running with the wrong distributor (it had the one for the DOHC engine). However, that problem was fixed quickly.
I did a few more driving tests, and the car jerks stronger (insert obvious sexual joke here) when in third of fourth gear from roughly 800 RPM to 1,500 RPM. The car currently idles around 1,500 RPM, occassionally dropping to 800-1000 RPM.
Coolant temperature sensor appeared to be fully functional when the thermostat was replaced, re: this topic I made
In other news, I hate that spot in front of the door that acts as a crap collecter >_>
- Fuel filter
- Fuel pump
- Timing belt
- Spark plugs
- Thermostat
- Coolant
- Oil and filter
- Muffler
