Coolant Thermosensors
Posted: December 4th, 2007, 9:58 am
by tehbrookzorz
Well, the car's been acting up a little. Under load and accelleration, the CEL comes on. I'm getting codes 9 and 69, both coolant thermosensor codes. I made sure my cooant was topped up properly, didn't seem to help. Now realizing that these codes only were coming on during accelleration under load, and that this code turns on the rad fan while it is set, I let the car run, got out and pushed back on the intake manifold. Every time the engine rocks back the rad fan turns on momentarily. Thoughts?
Posted: December 4th, 2007, 1:59 pm
by wytbishop
Without having a chance to study the cooling circuit, I would guess that when you tilt the engine, one of the coolant temp sensors either becomes submerged or ceases to be submerged in coolant and defaults to a state that signals the ECU to turn the fan on.
Something like that, just off the top of my head.
Posted: December 4th, 2007, 10:41 pm
by tehbrookzorz
That was my thought, and maybe it is the case. I tried bleeding the system of air as best I could, topped up, and pulled the two thermosensors nearest the coolant filler neck to make sure they were clean and properly connected. Can anybody tell me where the third thermosensor is off the top of their heads? Where else could I get an airlock that could set these codes?
Oh, and so that you're aware:
"When Code 9 is present, the PCME substitutes fixed calibration values for the various representations of engine coolant temperature used internally. The engine may idle roughly and may be hard to start. Timing and fuel delivery calculations will be skewed somewhat since the coolant temperature will be only an approximation. As well, to safeguard against overheating, the PCME will also activate the cooling fan constantly."
~Engine Controller Malfunction Codes
Note:
Corrected code numbers pulled in original post(17 & 24 are on my other car.... another story).
Posted: December 5th, 2007, 3:30 am
by Whisper
If you have 3 thermosensors, which I'm guessing you do, since you're a '92, they should all be on the neck, around the coolant filler cap. One is closest to you - black sensor fan switch, which turns the fans off (possibly the one you're having problems with); another one a bit behind it - green sensor which is the main sensor and reads coolant temperature for various purposes, including turning the fans on; and a tiny black one behind it with a single wire is the sensor for your dash gauge, and doesn't control any part of your engine or cooling system.
I think that should be all.
Posted: December 5th, 2007, 8:15 pm
by tehbrookzorz
I'll try swapping sensors with another car, but it seems like odd behavior for the cel to only illuminate under load & acceleration.
Re: Coolant Thermosensors
Posted: December 29th, 2007, 11:45 pm
by maryus
Sorry guys but what is the normal temperature for a KF-ZE engine ? mine stays always slight above the middle. It should not be in the middle ??? thank you
meanwhile i found out , its like that for the most of the ppl , and for a few is 1/2 ..
Posted: December 30th, 2007, 2:30 pm
by tehbrookzorz
Fixed my problem. Turned out to be a broken wire in the wiring harness behind the engine.
Re:
Posted: February 26th, 2009, 11:29 am
by alexskull75
Whisper wrote:If you have 3 thermosensors, which I'm guessing you do, since you're a '92, they should all be on the neck, around the coolant filler cap. One is closest to you - black sensor fan switch, which turns the fans off (possibly the one you're having problems with); another one a bit behind it - green sensor which is the main sensor and reads coolant temperature for various purposes, including turning the fans on; and a tiny black one behind it with a single wire is the sensor for your dash gauge, and doesn't control any part of your engine or cooling system.
hi, in your opinion if i have a 94 mx3 wiring and 94 klze with only one sensor for the fan can i install a kl31 ecu? thanks a lot. regards
Posted: February 26th, 2009, 1:04 pm
by Daninski
Damn, I just read this and was about to say bad wire when I read your fix. No soup for me. :(
Glad you got it fixed.
Re: Re:
Posted: February 28th, 2009, 5:30 am
by Whisper
I'm guessing yes, if it's a 94 ECU as well. Else it'll look for the extra sensor, I think.
Re: Re:
Posted: March 2nd, 2009, 12:23 pm
by kikkalazio
hi, in your opinion if i have a 94 mx3 wiring and 94 klze with only one sensor for the fan can i install a kl31 ecu? thanks a lot. regards[/quot
thanks , Excuse me for my delayed reply... i was able the find only one sensor for the fans in both the two engine. when i put the kl31 ecu the fans it's on all the time but when i put the k8 ecu the fans work fine. i also supposed that the kl31 ecu it's for the earlier model with 2 sensor for the fan. the problem is that it's near impossible to find the year of the kl31/36 ecu able to manage the single sensor. no one of the seller i was in contact was able to tell me how many sensor their ecu can manage... what i can do now? THANKS AGAIN
Posted: March 2nd, 2009, 12:50 pm
by alexskull75
don't worry bro for the delay,but please, reply on this thread and not on the private message cause i need the advice of the other guys on this thread who know more than me! anyway was exactly what happened to me with these damned the fans!, maybe the european mx-3 that has only one sensor for the fans control.
