Does anyone know what the compression should be?
Escort gt smokes when cold. I blame valve seals but then again engine is way to old. Its been trough hell. I actually rebuilt the head around 2 years ago. The pistons and chambers looked new back then. This must have been around 30 thousand miles ago or more.. we drive her alot. Compression test revealed even numbers. I forgot what it was.. i think 160 all across. I forgot. I need to retest.
I just need what the stock compression is for the BP 1.8 engine.
compression on bp 1.8?
hgallegos915
-hec
- Limegreen mx-3
i hope ur saying that a BPT casue no way in hell is that for a N/A BP-DElilredrocket wrote:8.2:1
160 is not bad but it should be around 180ish for the n/a bp these are what mine read
- cyclonekid78
Anything above 160 and within a 20% tolerance is good. The BP engines compression ratio is 9 to 1 and the BPT is 8.2 to 1. Try doing a wet test the next time you check the compression.
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
hgallegos915
Thanks you guys are awesome!
-hec
