I broke my Main fuse off in it's socket
Posted: December 1st, 2007, 8:28 pm
by zombiechow
Ok i may be an idiot and I am thinking I did something really stupid by trying to remove the main fuse. The 80 in the fuse box. Anyway I tried to remove it by hand and it seemed tight so i used a pair of pliars and I broke the dang thing off. Now I can't get what's left out and of course can't start my car. Am I going to have to buy a whole new fuse box. Did i remove it wrong? Obviously wrong because I broke it but what is the correct way? I should have read up but I still can't find the proper way to remove it here or on google. I feel so stupid. Can anyone give me an idea of what I am going to have to do? Thanks guys.
Posted: December 1st, 2007, 9:17 pm
by Dali
if i recall there is a bolt on each side holding the main cable to the fuse, pop all the clips off and the side will open to show them.
Posted: December 2nd, 2007, 12:54 am
by Whisper
Yeah, you have to unscrew it from both sides.
Posted: December 2nd, 2007, 11:03 am
by zombiechow
ok...great i will try that...also are all the fuses tops supposed to be flush? My second 30 fuse from the top is sticking up a little and I can't remember if it was like that before all this happened. It seems to be all the way and there isn't anything stoping it.
Posted: December 3rd, 2007, 12:14 pm
by zombiechow
hey thanks again. I got it running and it's working great. Replaced the neg. ground wire and gave it two new terminals and no more sparks. Also I think it was sparking because I had the door open..duh right? Anyway. Thanks for the help. Didn't know there where two bolts holding it in. All's well that ends well and as long as we learn from our mistakes it not really a mistake as much as a learning experience. :)
