Can anyone tell me if the bolt patter for the strut bar for an mx6 is the same for the mx3?
My friend and I are going to try to cut an mx6 strut bar for an mx3 and want to know if anyone knows if the bolt pattern is the same?
Strut Bar Conversion
umm do you currently have the mx-6 stut bar? couldn't you just fit it on the strut tower to see for yourself??
why not buy a cheap ebay one for an mx-3??
- solo_ryder
Re: Strut Bar Conversion
Front bar is the same bolt pattern, the rear bar will have an issue because the bolts are closer together then the mx6's. I dont see why you would want to do this though..mx3mayhem wrote:Can anyone tell me if the bolt patter for the strut bar for an mx6 is the same for the mx3?
