Page 1 of 2
V6 Swap with too much gas
Posted: November 4th, 2007, 8:41 pm
by Greyguild
Hi, I swap my 1.6 4 cyl for a 1.8 v6, I finally got it to run yesterday but this morning, don't wanna start, it turn over but nothing, when I remove a spark plug and try to start it, it blow the fuel out and when I stop the starter I can see the fuel dripping on the piston, I checked my PRC Valve hoses and they seem ok, any suggestions for me please...
Another thing, my fuel is kinda old, its been in the car since last January, when the 4 cyl died, can it be the problem or only a factor?
Posted: November 4th, 2007, 8:45 pm
by mx3autozam
do you got spark?
Posted: November 4th, 2007, 9:32 pm
by Vanished
HAhaha it's probalby got bad gas...if it's been there since last YEAR.
Wow...syphone your gas, put it some new stuff, change your plugs and make sure you have spark, and report back.
Posted: November 4th, 2007, 9:52 pm
by Greyguild
I have spark...
yesterday it did start and after a while started to get low in rpm and started to run kinda square...
I will remove the gas and come back with ya on this...
Posted: November 8th, 2007, 4:01 pm
by Greyguild
OK I kept the gas in th car (maybe a mistake) I added a bottle of cleanflow to remove the water in the tank and the day after I added a good 5 gallons of Super...
And still, it will start do a couple turns and then die, if i retry right away nothing, if I wait a 30 to 45 seconds, it will start again for a couple turns and then die again...
I'm baffled....
Posted: November 8th, 2007, 4:50 pm
by Juans_93_MX3
My MX3 sat behind my house for 2 years. Turned it on a few times.
Never had a problem. I highly doubt it was bad gas
Posted: November 8th, 2007, 4:56 pm
by Mooneggs
but wont' gas go bad if it just sits for a long period of time??? doesn't something evaporate or something... maybe this is a noob post :oops:
Posted: November 8th, 2007, 7:32 pm
by 94mx3precidia
the octane degrades.
Posted: November 8th, 2007, 9:56 pm
by Greyguild
Should I add an octane booster to the tank then?
Posted: November 9th, 2007, 7:19 am
by mx3autozam
How juch gas is in the tank?? if not much than just fill it right up with 91.
Posted: November 9th, 2007, 6:35 pm
by 94mx3precidia
well even iff your gas in your tank didnt have a high octane rating it should start.
But it wouldnt hurt to put a jerry can of 91 in your tank. BTW there is a drain hole in our cars so its pretty easy to drain the tank.
Posted: November 9th, 2007, 11:00 pm
by mx3autozam
94mx3precidia wrote:well even iff your gas in your tank didnt have a high octane rating it should start.
If it has a factory tank. My replacement aftermarket one didn't and same with a few others I have seen.
Posted: November 10th, 2007, 10:48 am
by Greyguild
Its a 323 tank, I think it has the drain plug... gonna check that tomorow
Posted: November 11th, 2007, 11:48 am
by 94mx3precidia
ya If your tank is original the mx3's and 323's gas tanks are identical and they both have drain plugs. Just make sure that you change the drain plug washer with a new one. And also spray some rockerguard on the drain hole so that it doesnt rust in the futurte.
Posted: November 19th, 2007, 8:41 pm
by Greyguild
I emptied the tank, changed the fuel filter and added new fuel, stuill no go, it want to start and then stop... Im starting to think about a loose connection, any suggestion where i should look?
