Wankel Engine.
Posted: September 17th, 2007, 1:18 pm
by steckino
Well just came to mind that my friend's friend has a Wankel engine. I've seen it once and I didn't take note to how it mounted in there, I'm sure it was entirely different from a MX-3. I am just wondering how possible it would be to take the engine and EVERYTHING else from the 86 RX-7 and make it into a project for an MX-3. I know it must sound stupid... but I am just wondering.
Re: Wankel Engine.
Posted: September 17th, 2007, 2:18 pm
by monty73741
steckino wrote:Well just came to mind that my friend's friend has a Wankel engine. I've seen it once and I didn't take note to how it mounted in there, I'm sure it was entirely different from a MX-3. I am just wondering how possible it would be to take the engine and EVERYTHING else from the 86 RX-7 and make it into a project for an MX-3. I know it must sound stupid... but I am just wondering.
yes u can but there are alot of custom fabricating in vovled
Re: Wankel Engine.
Posted: September 17th, 2007, 2:27 pm
by steckino
monty73741 wrote:steckino wrote:Well just came to mind that my friend's friend has a Wankel engine. I've seen it once and I didn't take note to how it mounted in there, I'm sure it was entirely different from a MX-3. I am just wondering how possible it would be to take the engine and EVERYTHING else from the 86 RX-7 and make it into a project for an MX-3. I know it must sound stupid... but I am just wondering.
Do you know of anyone who has done this modification, so I could get an estimate for the frabrications. I am figuring that it would be pricey. Around 1,000 or more?
Posted: September 17th, 2007, 2:49 pm
by Tunes67
Posted: September 17th, 2007, 3:59 pm
by steckino
under the product page it says RX3. What about from an RX-7? :\ or is it the same engine?
Posted: September 17th, 2007, 4:10 pm
by Tunes67
Look more specifically at the adapter kit for the 323.. it should work with only minor modifications (if any) And... while I could be wrong here.. I think if it can adapt a 12a.. you should be able to use the kit (again with possible modifications) to adapt in a 13b.
Tunes67
Posted: September 17th, 2007, 7:48 pm
by steckino
uhhhh yeah never mind. It would cost over 4 grand just to put it in
With all that money gone I might as well have gone for a BP swap.
Posted: September 17th, 2007, 8:08 pm
by Tunes67
4 grand??? Did you call that site and ask or something? Just curious
And it doesnt surprise me that putting in a Rotary would be expensive.. if it was cheap.. someone would have done it a long time ago LOL
Tunes67
Posted: September 18th, 2007, 12:05 am
by Dark_Rider2k3
When i get up a lot of money, have more knowledge with cars, and I can afford another Mx3, I might just try doing this type of swap. It sounds interesting and pretty awesome...
Posted: September 18th, 2007, 5:55 am
by hotsiit
I have no idea on costs, but anything can be done with enough $$$. I love the rotary too, so I got me an rx-7 to go along with my mx-3.
Posted: September 18th, 2007, 11:05 am
by Mnemonic
i've been saying it for years that you can swap a rotory in an mx3 using the kits they make for 323s, you'd only need slight modifications and i still believe you can do it keeping it fwd.
Idealy you would want it to be rwd, but the easiest way i figure to do that is to get a awd 323 and use the car just for parts, swap over rears, then get you a 2nd gen rx7 setup cut and fab up a new firewall around the transmission.
If you have the right connections i could see this swap being possible for less than 10k BUT 10k put into a kl motor would yield more power as this is just getting a basic 13b single turbo in the car, but the rotory would make far more power later down the road
Posted: September 18th, 2007, 10:18 pm
by steckino
Mnemonic wrote:i've been saying it for years that you can swap a rotory in an mx3 using the kits they make for 323s, you'd only need slight modifications and i still believe you can do it keeping it fwd.
Yeah.. my friend has 2 86 RX-7's just sitting in his yard... one has a wiring problem and won't start while the other one hit a telephone pole in the rear end.... :sigh:... he spun himself around for reference... lol
Posted: October 15th, 2007, 6:44 pm
by PGT97_Racer
Seems like a lot of work and money to do. The engine would probably fit, but the RWD conversion might be a bit tricky
