ZE heads on a K8
ZE heads on a K8
Has anyone ever put ZE heads and IM on a K8 block?
Just curious... I think i may need to replace the heads shortly.
				hgallegos915
I had heard they dont bolt up or something
							-hec
				Mnemonic
SEARCHING says NO
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- 1992blazeredgs
It would be interesting to try and see if it works.  Having just rebuilt a klde and than tore apart my k8.  I am sure the heads would bolt to the block. However i think the problem will be the difference in size of the combustion camber on the head to the cylinder size of the k8.  I doubt a proper seal could ever be achieved.  This is just my two cents having recently seen both motors apart.
Nate
							Nate
Looking for another Red GS.
						- mx3autozam
I donno if it works or not. it shoudl bolt up no problem, but you would need to use k8 head gaskets and they might interfer with valves opening. Think thats what i read.
But I've always wondered what a k8 would be like with kl31 cams, curve neck manifold, headers and full exhaust and a fidanza. I recenently blew my ze up and thats my mods on it. I've been debating running a k8 in the meantime while i build a motor. I bet that thing would rev to high hell. I would love to see a dyno for that as well.lol
93 Mazda MX3 KLZE Turbo
				Mnemonic
its already been tried you have to relise while yes they will bolt right up the coolant channels are not the same plus you have the issues with the valves, so could you bolt them right up sure, is it like honda motors where you can swap heads between motors, no
				Mnemonic
why even try to build up a k8, its a waist of time and money to do so, the internals of the block are bunk and it would be just as easy/cheap to send your heads to have port and polished and a more agressive 3 angle valve job, and you would get the same ending as the klze heads
				hgallegos915
Just do it and let us know how it went.
							-hec
- mx3autozam
