Flywheel milling
Napalm7629
Flywheel milling
I have the means of machining my flywheel in order to save weight, but does anyone know how many thousandths it is good to remove in order to get a noticeable amount of power?
Napalm7629
- Tunes67
It will also reduce the amount of low end torque you have as well. You wont be able to shave enough off of your flywheel to notice much of a difference.. go Fidenza or however its spelled.. they have a real light weigh flywheel 8-9 lbs I think. Cheers
Tunes67
Tunes67
