My 94 dash swap Pictures (lots of pics)
Posted: March 25th, 2007, 4:22 pm
by Greyguild
1st of all I am only an enthusiastic amateur, not a professional and this installation is not quite finish to this day...
Last Summer I found a Junkyard that had a few MX-3 and specially one with a pristine 1994 Black dash, so I grabbed the entire black interior for a mere 150$ CAN... My MX-3 is a 93 with a Tan interior as you can see in this pic (Sorry poor quality pictures)
And this is the beauty I picked up in the Junkyard
First I removed the 93 dash
Saved the 93 dash wiring
Had to cut off 1 of the cluster bracket cause my dash have a cable speedo and that bracket was interfering with the cable (center of image)
The center bracket on the 94 dash had to be modified to slide onto the existing floor brackets in my car
And Notches where made to accommodate the 94 side bracket to kinda fit in between the 93 body brackets (I hope you can follow this)
I kept the 93 wiring, it was easier to interface them with the 93 main fuse box. I also had to change almost all the connectors to every buttons or switches on the 94 dash, but at least the wires color coding do match between years
And this is the final product
And the day after
Added some plasma gauges and Aluminum rings around the gauges plus changed the clock and turn arrows color blue to match the gauge faces
Conclusion:
Up to this day, the floor brackets aren't bolted yet and I have to reposition the sides brackets, the climate controls had problems with the cables so I had to unhook them... Thats about it, all the switches work nicely and the look is a lot better...
I hope my post has been useful to someone, next step is an engine swap and a rear disk brake conversion, wish me luck ;)
Posted: March 25th, 2007, 5:33 pm
by solo_ryder
Good writeup! should be stickied or in FAQ :)
Posted: March 25th, 2007, 9:12 pm
by 92blackmx3
i did this swap too itspretty easy i took the main bar/bracket off the back of my 92 and put it on the 94 and putmy cdplayer where the heater controls would goes its worth it
Posted: March 25th, 2007, 10:14 pm
by PATDIESEL
Neat. Where did you get the rings for your guages. I've wanted some for mine since forever ago.
Posted: March 26th, 2007, 8:27 am
by Greyguild
Actually its probably my error I didn't remove the back bar I decided to keep the 94, bah it shouldn't be a problem I will re-weld it to the right place anyways...
And for the ring i got them from eBay germany, but i saw a few on eBay US recently...
Thanks for the comments ;)
Posted: March 26th, 2007, 10:35 am
by neutral
Nice job. Looks like a lot of work but it looks great.
Great job
Posted: May 15th, 2007, 11:21 pm
by racer3v
That looks awesome. Now I am contemplating doing it in mine. I really need to post some pics of mine so I can get some ideas. You have given me a huge one though. Great job!
