chewed up starter? Tranny filler bolt?
Posted: March 17th, 2007, 10:31 pm
That's right, I pulled the starter as part of the process of pulling the tranny for my clutch and shift fork replacement and the starter was chewed up. Basically the metal that covers the section where the starter gear is when not engaged is chewed up. I looked in the whole for the starter and the edge of the clutch pressure plate appears to be what did it but I don't see how that is possible. I have a used starter to replace it but just dont understand how it happened. The starter was a used starter from a 2001 Millenia. The one I have to replace it is from a 96 MX6. I haven't gotten a full look at the pressure plate yet as we haven't gotten the tranny off. Ran into numerous stubborn bolts. For the axle nuts we needed a half inch breaker bar with a 5 foot long pipe on it to break them loose and that was after heating them up even. Another question while I'm at it, I've searched and found that the bolt for filling the tranny uses a ratchet without the socket only my 92 GS don't have one anywhere on the tranny. I see a few bolts that appear to be possibilities but wanted to ask first so I don't try something that isn't suppose to come out. Lastly, how exactly is the easiest way to get the passenger side axle out? On my sentra it's a merely a straight axle from the tranny to the hub so this is kinda new to me. Hopefully we are past the worst of it. We are planning to start early tommorow and hopefully get it done by the end of the night.
