poly bushings
Napalm7629
poly bushings
Post by Napalm7629 »
I did a search and I didn't come up with anything very useful. So I am sorry if this is a repeated posting.
I am looking for a poly bushing kit for the 1.6L. I have been looking but as far as i can tell, one is not made. Does another kit made happen to fit the mx-3? Pretty much everything rubber under my mx-3 needs to be replaced, all bushings, ball joints, and tie rod ends. So i figured why not replace then with something that will last a bit longer. If you could point me in the right direction i would appreciate it!
Napalm7629
Trevor
Post by Trevor »
Super pro makes bushings for the MX-3 I got mine from Donny at http://www.therpmstore.com. Email himwith what you need and he should be able to get it. You need to measure the rear bushing on the front lower control arm, and the rear bushing on the trailing arm as there are 2 differant size bushings for each. Here is Donny's email.
donny@therpmstore.com
Napalm7629
okay great! thanks a lot...do you happen to know about how much like a full kit would cost?
Napalm7629
Trevor
Post by Trevor »
I did my complete rear bushing set with front control arm bushings for about $500 usd
