i was woundering if there is any special lub. for the slide on the Moon Roof? cause mine is moving offly slow. Please Help..
thanks
Chris
Moon Roof
Moon Roof
"Demized Concepts" My Friends and mine car club. also on myspace.com
http://WWW.Myspace.com/demizedconcepts
- Tunes67
White Lithium Grease works well. Its relatively thin but long lasting.. perfect for those sliders.
Tunes67
Tunes67
- neutral
Ditto on the white lithium - comes in a spray can with an extension tube for easy application. My last lube-around on window regulator and sunroof tracks I started using a silicone spray lube, which seems to last longer and attract a bit less dirt. Can't recall the exact name but it was the NAPA autoparts house brand.
- Tunes67
Clean and lube the tracks. Also.. clean and or replace the switch.. its probably worn out from years of use. Taking it apart and cleaning the contacts with q-tips & alcohol may help improve conductivity and help it work better. Lubing the tracks will make it that much easier to move.
Tunes67
Tunes67
