Knock Sensor check? resistance, capacitance?
Posted: January 20th, 2007, 4:23 pm
ok, guys. not too sure how these knock sensors work, but I am getting a check engine code 05. I tried doing a continuity check on my knock sensor at the connector and it read open. Is that OK, or is there supposed to be some resistance value (ohms)?
has anyone ever checked those. I need to make sure the sensor is actually faulty as I refuse to do that much disassembley to change a sensor that is perfectly fine. thanks
