Need Engine Identification
Posted: January 11th, 2007, 1:28 pm
by jorcool13
Does this engine is real bp from a 91-94 or is the OBDII from 95-98 with internal coil for the ignition?
http://cgi.ebay.com/ebaymotors/JDM-MAZD ... dZViewItem
Didn't the mazda bp 91-94 had a black valve cover, OBD-I, and external coil for the ignition?
Posted: January 11th, 2007, 3:36 pm
by Campbell*
looks like a 95+ BP
Posted: January 11th, 2007, 3:41 pm
by jorcool13
yeah! thats what I was thinking! Any other comments? Please HELP!
Posted: January 11th, 2007, 3:54 pm
by 94blaze1.6
That looks like a newer BP (95up) But if it has a b6 stamp on it then its a b6 because I have a b6 and it looks like that, but then again the newer bp and dohc b6 look alike so check the block stamp!!!!
Posted: January 11th, 2007, 4:04 pm
by jorcool13
yes! I told the seller to send me a photo of the engine stamp! If it is 95+ the swap to my 1.6 DOHC will be more dificult?
Posted: January 11th, 2007, 4:41 pm
by 94blaze1.6
If you have the DOHC this newer bp can be swapped fairly easily check out this link this is the only documented 95bp into DOHC b6 mx3 swap (IT is automatic so a little different plus he had a whole protege donor car) Definetly can be done
BP 91-94 vs 95+?
Posted: January 11th, 2007, 11:36 pm
by jorcool13
What are the differences on this engines, wich one is better and wich one is easier to take power off it
Posted: January 11th, 2007, 11:38 pm
by jorcool13
Posted: January 11th, 2007, 11:39 pm
by 94blaze1.6
Posted: January 11th, 2007, 11:41 pm
by 94blaze1.6
Posted: January 11th, 2007, 11:42 pm
by 94blaze1.6
that is a bp then...
Posted: January 12th, 2007, 12:02 am
by jorcool13
I can't find anything on wikipedia!
Posted: January 12th, 2007, 12:16 am
by 94blaze1.6
Did you even look at the link? cause its there! here it goes from the link i posted:
BP
The 1.8 L (1839 cc) BP is a dual-overhead variant of the B8. It was first found in the 1989 Mazda Familia and American-market 1990 Mazda Protege LX. This engine was dubbed BP-ZE and featured a forged crankshaft, piston oil squirters, an aluminum baffled oil pan, and VICS. This particular variant can be found in the following vehicles:
1989-1994 Mazda Familia GT (European & Australian Market)
1989-1994 Ford Laser TX3 (Australian Market)
1990-1994 Mazda Protege LX (with VICS)
1990-1994 Mazda Protege GT (Canadian Market)
1990-1993 Mazda 323 (European Market)
1992-1993 Ford Escort LX-E
1991-1996 Ford Escort GT
1991-1996 Mercury Tracer LTS
1994-1997 Kia Sephia GS
1994-1998 Mazda Familia (Japanese Market)
1994-1997 Mazda MX-5/Miata (this did not have VICS until 1999)
There is also a non-performance version that is most easily recognized by its black stamped-steel oil pan. It also features a cast crankshaft, no oil squirters, a plastic oil pickup tube and less aggressive camshafts. It is found in the 1995-1998 Mazda Protege ES.
B6D
1.6 L B6D - 1597 cc (78x83.6 mm) - The same strengthened and fuel-injected 16-valve DOHC B6 but with higher compression, no turbo, and the first Mazda engine to feature VICS (Variable Inertia Charge System). Most commonly found in the 1985-1988 Japanese market Familias, Etudes and Lasers, this engine was updated in 1989 with revised compression, heads and intake system (in a similar vein to the B5 DOHC) for the 1989-1991 Familia and Laser, then further refined for the 1991-1994 Mercury Capri and 1994-1996 2nd Generation Mazda MX-3 RS. The third generation B6D features a silver cam cover.
