As i weas going through weight reduction stage 500 : P i noticed this module type thing on the passenger side, i have a video of it . Hope sonme one can tell me what it does cause inm to lazy to trace wires and such : (
vid:
http://www.members.paraparamatsuri.com/ ... module.wmv
Mystery Module, what is this and what does it do??
- XxantwawnxX
- XxantwawnxX
thank you verymuch, i have not had cruize control in over 4 years, so i guess its coming..woo another half pound shaved.
WOW your camera takes BEAUTIFULL video.. what kind and pics of it? and how much?
-hec
- XxantwawnxX
well its just an old JVC mini DV cam..not exp or anything..and old. I think its the way i encode it...all DV cams have about the same quilty AVI record...but when u encode it to MPEG thats when the qulity gets crapppppy, i have a special way i do it : P
