Page 1 of 2
KLZE in Kamloops, BC
Posted: November 28th, 2006, 12:50 pm
by JMac
Anybody running a ZE in Kamloops. I have installed engine in my 92 MX3 and am waiting for ECU. Would like to take a look at your setup.
Posted: November 28th, 2006, 1:13 pm
by Dali
i dont hink there is anyone in kami with a klze in the mx3, im in williams lake, there are a couple of guys in pg and then in kelowna/vernon. what did you need to know?
Posted: November 28th, 2006, 1:24 pm
by solo_ryder
Hey, there was a guy in loops, but he has sold the car. I am in vernon and the sole ZE'er around lol. There are some other guys, but they do not go on the board.
Posted: November 28th, 2006, 7:11 pm
by Darcy
Kevin, (Ovendnk on the boards) was in Kamloops from Ontario... not sure if he's still there though. It may have just been in the summer for work.
He had a pretty pimped ride... complete custom interior.
Posted: November 28th, 2006, 10:04 pm
by JMac
My engine is in and waiting for KL31 ecu. What did you do with your EGR and did you bother to connect up the solenoids for EGR?
Posted: November 28th, 2006, 10:49 pm
by solo_ryder
EGR came out. Just left all that crap. Threw out all that vaccum stuff that was on the old aribox. Connect the FPR to the IM.
Posted: December 3rd, 2006, 4:02 pm
by Talon_66
solo_ryder wrote:Hey, there was a guy in loops, but he has sold the car. I am in vernon and the sole ZE'er around lol. There are some other guys, but they do not go on the board.
I was the guy in Kamloops with a KLZE MX3. I wasnt the first person in Kamloops to run a KLZE however, there is a Probe GT turbocharged with a KLZE in Kamloops. I was the first MX3 KLZE though
When I come into Kamloops next I'd like to check out your car. Are you on Intencity?
Posted: December 11th, 2006, 11:51 am
by JMac
I have installed the KLZE with MS8 curved manifold, KL31 ecu, new disty,timing belt, phenolic spacers, water pump and disconnected EGR and solenoids. Having a problem with fuel injectors. Have good spark but do not seem to be getting fuel. Fuel pressure is good but injector voltage seems low and not firing. Cleaned up ground wires, checked timing, spark etc. Suspect bad fuel rail or wiring problem. Anyone out there have similar problem?
Posted: December 11th, 2006, 1:40 pm
by solo_ryder
Not that I know of, try posting in the v6 forums to see what they say about that. How are the plugs that go into the fuel rail? Is your FPR hooked up correctly?
Posted: December 11th, 2006, 9:52 pm
by Talon_66
JMac wrote:I have installed the KLZE with MS8 curved manifold, KL31 ecu, new disty,timing belt, phenolic spacers, water pump and disconnected EGR and solenoids. Having a problem with fuel injectors. Have good spark but do not seem to be getting fuel. Fuel pressure is good but injector voltage seems low and not firing. Cleaned up ground wires, checked timing, spark etc. Suspect bad fuel rail or wiring problem. Anyone out there have similar problem?
Sounds like a pretty good set up.
I also had the MS8 Intake and the same ECU. I disconnected and removed all the EGR from my car, charcoal cannister.
Would definitely like to see your car.
Posted: December 11th, 2006, 10:20 pm
by Dali
ive had this same problem on 2 mx3's, turned out both times it was the wiring harness going into the ecu, the pins were loose. on one car i would loose one injector, on the other i would loose all six or they would just piss out a ton of fuel.
Posted: December 13th, 2006, 10:46 pm
by JMac
Plug in to fuel rail seems good. Getting mechanic to have a look at wiring to trace the problem. I turn ignition on to start engine and noticed the radiator fan still runs after trying to start (key still on) . Do you know if this is common? Sound like a wiring problem?
Posted: December 14th, 2006, 12:48 am
by solo_ryder
jmac, we gotta meet up sometime dude. I am only 1 hour away
Posted: January 8th, 2007, 11:28 am
by JMac
Found the problem. Partial ground inside plug connection going up to heat sink near firewall. Repaired connection and motor is running like a top. Had been checking all ground connections and noticed small burn mark on plug connection. This partial grounding would not let ECU fire injectors. Disconnected all EGR plugs, removed two solenoids, EGR and plugged EGR connection to exhaust manifold. Set up timing to 10 degrees and the idle to 750 rpm.
Zoom Zoom, this engine runs smooth and pull allot harder than the stock 1.8. The difference is outstanding. Will be taking car up north (St. John)for a few months so if anyone sees the bright yellow MX3, take a look.
Posted: January 22nd, 2007, 4:46 pm
by wyldside
Just an FYI but the MS8 intake is the Straight neck intake, not curved. You probably have an intake from a Xedos9, Eunos800, or Millenia. Those are all curved neck intakes with square runners.
