New headbolts
New headbolts
I have my head off of my 94 mx3 1.6 and when i put my head back on do i have to get new headbolts to put it back on or can i use the old ones. Cause the cheapest head bolts i have found are $104.
- Tunes67
You can re-use your old ones as long as the threads are in good shape. Run a die down over the threads to clean up the threads of the bolts and then run a tap down the bolt holes of the block. Lightly oil each bolt in the threads (only a little bit) before you put it back in.. this will give you a more accurate torque result. If you find any pitting or cracking in the threads.. or.. if the bolt & threads appear stretched, replace them.
Tunes67
Tunes67
- Shades
If you are gonna buy new headbolts, might as well buy ARP head studs... they're about the same price.
But I believe those bolts are not torque-to-yield bolts, so you should be okay to reuse them. Make sure you torque them back up to spec!
"Do it ONCE, do it RIGHT!"
- Tunes67
Shades is correct.. the bolts are not torque to yield bolts.. Having rebuilt the head on my 94 RS.. I can attest to this.
Tunes67
Tunes67
