[WTB] E-Spec Headlights
Posted: September 30th, 2006, 4:39 am
by illapino
those with clear lens & h4 bulbs
reply here. thank u.
my car is 1992 Mazda MX-3 Precidia. don't know whether my existing headlights would be North American spec or J-Spec then, since this car was made in Japan ....
Posted: October 1st, 2006, 4:27 am
by Aston Wards
I've got some j-spec headlights...., but they don't have the clear (glass) lens, i believe you're probably after the E-spec units (even better cos they're LHD too)
Posted: October 4th, 2006, 4:32 am
by illapino
isn't there even an online store that sells these ?
Posted: October 4th, 2006, 10:00 am
by Custommx3
Only ESPEC are glass. Everywhere else has lexan.
Posted: October 4th, 2006, 8:37 pm
by Steeb
are the espec clear? i thought they have the pattern on the lenses also
Posted: October 6th, 2006, 3:01 am
by mx almere
Steeb wrote:are the espec clear? i thought they have the pattern on the lenses also
That's correct.
Posted: October 6th, 2006, 8:30 am
by illapino
illapino wrote:isn't there even an online store that sells these ?
Posted: October 9th, 2006, 12:37 am
by jschrauwen
illapino wrote:illapino wrote:isn't there even an online store that sells these ?
Not that I'm aware of. Most people get them from ebay or one of the other Forums from Europe. I may have my set of J-Spec ones available when my projectors get done.
Posted: October 16th, 2006, 1:59 am
by illapino
none on ebay at the moment, or the moment before
Posted: October 16th, 2006, 11:12 pm
by Aston Wards
It's possible i still have the harness for H4 bulb headlights from my old parts car, i know i have headlights laying around.
Maybe you can just use the j-spec harness in your MX-3? or is it the headlights that are not compatible with the H4 bulbs??
Posted: October 17th, 2006, 11:21 pm
by illapino
test
Posted: October 23rd, 2006, 11:19 pm
by jschrauwen
Aston Wards wrote:It's possible i still have the harness for H4 bulb headlights from my old parts car, i know i have headlights laying around.
NA Spec lights won't accept the H4 bulb mount. The J Spec harness can be adapted to NA Spec MX's. There are other subtle differences between the 2 spec light units aside from the beam pattern being orientated for RHD as opposed to LHD. The manual beam adjusters are different between each other which also translates into different internals between the 2. The beam adjustments for J Spec / E Spec is accomplished throught the movement of the internal reflective lense. The NA Spec units internal reflective lense is fixed and the beam adjustment is accomplished via an external bracketry system that the light unit is attached to whereas the other spec units are hard mounted to the frame. I hope I didn't make that too confusing.
Posted: October 24th, 2006, 8:51 pm
by illapino
well, i get ur drift, but if i read you right, u also discouraged me from getting interracial with my headlights
god, i have to find a picture of the lights i want.
e-spec j-spec, i don't even know! the one with the clear lens and nice reflector inside!
Posted: October 24th, 2006, 8:55 pm
by illapino
here we go
these are the headlights i want:
