How to unscrew plastic?
Posted: September 22nd, 2006, 7:03 am
by Tropical Emerald 1993
I need to get behind gauges to check the speedo cable. I've checked out the faq and unscrewed everything around but it won't go down.
The plastic around gauges won't go down because the plastic around the wheel is holding it. Plastic around wheel won't go down because of the wheel. Also the whole plastic below won't go down since it's held by plastic above (from the doors side).
Any idea on this? I didn't expect this to be that difficult.
Posted: September 22nd, 2006, 6:04 pm
by Julz
Not triying to be funny, but did you unscrew all of the screws including the 3 that are up under the dash?
Posted: September 22nd, 2006, 6:18 pm
by Dali
there are 3 srews on top of the gauge hood and two behind the rubber right where the steering cover hits on the bottom of the gauge hood, but as far as i ever seen there is no speedo cable going to the gauge cluster.
Posted: September 22nd, 2006, 6:28 pm
by atlantamx3
Dali wrote: but as far as i ever seen there is no speedo cable going to the gauge cluster.
Umm YES there is.
The ONLY way to undo the Speedo Cable & therefore remove the cluster is to undo it where it goes into the transmission. This will allow you enough slack to pull the cluster out and undo the speedo cable at the rear of the cluster.
Posted: September 22nd, 2006, 6:59 pm
by solo_ryder
Thats strange I have never seen one, I may be looking in the wrong place, this is not specific to 4cyl's is it?
Posted: September 22nd, 2006, 11:23 pm
by atlantamx3
92-93 4-cylinder models only.
All years of the GS and the 94+ RS has electronic speedometers.
Posted: September 23rd, 2006, 1:03 am
by solo_ryder
Ahh that makes sense, I thought both my mx's were missing somehting for a min lol. Yea I had a old 626 and you could not pull out hte guages, you gotta undo it from the tranny as described. PITA
Posted: September 24th, 2006, 2:09 pm
Dali wrote:two behind the rubber right where the steering cover hits on the bottom of the gauge hood
yes I'm having trouble with these two because I can't get down the steering cover. I've unscrewed all but still won't go down
Posted: September 24th, 2006, 2:34 pm
by solo_ryder
There are 4 screws underneath. You also have to take the ring out that goes around the ignition. The you can carelfullt pull it apart as there is tiny little clips that losely hold it. Make sure you also move the tilt handle down and check to make sure all 4 screws are out.
Posted: September 27th, 2006, 2:21 pm
solo_ryder wrote:Make sure you also move the tilt handle down and check to make sure all 4 screws are out.
Oh yes, now that I've lowered the wheel I can get ot off. Thanks.
