brake booster/boost question.
I understand the basics of how the brake booster works. My question is under boost am i dragging my brakes? If so how do you fix that?
							[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
						- PATDIESEL
You can check the check valve by taking the tube off and blowing through one and and then the other. Air should only pass one way and not the other. Make sure you put it back on the right way or you loose power brakes. (don't ask how I know that, LOL)
um ok i wont ask but im sure same way i found out not to put my hand on the motor when im arking out the coil to see if its firing
						no brake boost
Ok. I have the 1.8 BPT installed in my MX3. 1.6 SOHC originally. Saw this post.... I suddenly do not have good braking. Is there something that came off? Feels like I have to really put effort when braking.
-Val
						-Val
- ryanlindenberg
are you running a check valve?  i've heard of people ruining their master cylinder because they don't have a check valve so their master cylinder is getting boost pressure to it.  something about a diaphram if i remember correctly.
anyways, on a related topic, does anyone know where you can buy a check valve that would work good (maybe an 8-10mm inlet and outlet). local parts stores don't have anything close to what i need. i'm currently running one with a smaller inlet/outlet and it makes a high pitched whistle when air passes through... just an annoyance.
CARDOMAIN WITH UPDATED PICS
