Flywheel
93_4Banger
Flywheel
Will the sohc flywheel fit the bp?
Kuromu
If you are still using the F-series transmission that came with the SOHC, then yes. If you upgrade to the G-series transmission that came with the BP, then you will need to use a flywheel made for that trans.
93 MX3 RS BP 2.0 // 87 RX7 HKS Turbo
- Limegreen mx-3
Yes as long as u use ur sohc f-series trany. look at my links
