Page 1 of 3
how much horse power
Posted: May 11th, 2006, 5:48 pm
by mazda(v6)
well, me and my dad just pulled a klde from a mx-6 and i was thinking b4 i put it in my mx-3 i should send my head and stuff to gude, i was wondering what would be a good estamate of hower much hores power should it put out? Like 290hp?
Re: how much horse power
Posted: May 11th, 2006, 7:46 pm
by lakersfan1
mazda(v6) wrote: Like 290hp?
It wouldn't even put out 290 CANADIAN horsepower ..... unless you're going to add a turbo kit.
Posted: May 11th, 2006, 8:35 pm
by fieromx3
a stock kl-de has 164hp and 160tq with head work like porting probly like 175MAX if that
Posted: May 11th, 2006, 8:46 pm
by mazda(v6)
no not just the porting im talkin bout the whole thing like headers,ecu,porting,ported manifold,ported throttle body,race valves,and new cylinders
Posted: May 11th, 2006, 9:00 pm
by Devlin
you'll only ever see those numbers if u turbo. u can do all the porting in the world, and even w/ all those mods you'll still b no more than the ZEs with minimal.
not saying it won't b fun...just don't b expecting 200+
Posted: May 11th, 2006, 9:17 pm
by Dali
canadian horsepower??????
Posted: May 11th, 2006, 9:25 pm
by twoie
now that's funny
twoie
Posted: May 11th, 2006, 9:35 pm
by Dali
Posted: May 11th, 2006, 10:42 pm
by 2.5mazda
Its a canadian thing, you wouldnt understand. :o 8) :twisted:
Posted: May 12th, 2006, 12:46 am
by Cy
Canadian maple syrup is better then american... In saying... all things canadian must be better.. Ar-go
Canadian HP = Better HP :D
Posted: May 12th, 2006, 2:18 am
by ninjajim4
whats the current exchange rate?
Posted: May 12th, 2006, 2:37 am
by Nd4SpdSe
Think Canadian hp vs american hp like canadian vs american gallons. ;)
Like mentioned, the KLDE makes 164hp and 16tq, but those numbers are at the crank. By the time you get from the crank, through the drivetrain and to the wheels, you'll loose quite a bit of power, usually somewhere around 15% on a manual transmission. I've going for an all N/A setup. From what I've seen, doing as much to the engine/drivetrain as possible, you'll usually get around the bhp (brake hp) value, but in whp (wheel hp). I would expect a max of around 164whp, which would translate to roughtly 189bhp. I haven't done any research in a long time, but when I last did on probetalk, I don't think anyone has broken 200whp on a KLZE, which would be roughly 230bhp.
Posted: May 12th, 2006, 3:32 am
by PWRD_BY_HKS
ummm.... thats alot of ponies.... but you wont get it all motor ...... well unless ...$$$$$$$$$$....... you know try building it for boost if you cant financial adhere to it nitrous will work too...hey its not the same but tell that to your quarter mile time
Posted: May 12th, 2006, 9:14 am
by ho bag
mazda(v6) wrote:no not just the porting im talkin bout the whole thing like headers,ecu,porting,ported manifold,ported throttle body,race valves,and new cylinders
Based on that statement i think you might wanan reconsider what your are about to do.
If your going all motor you are gonna want to raise compression to somewhere around 10:1 - 11:1. Your gonna want new rods to take the extra stress from spinning the motor higher. Your gonna want more agressive cams. Headwork would be very nice after all that. Ported intake manifold and throttle body. Vales should be ok stock but a valve job should be done with the head work.
In the end your basically building a ZE..... BUT with all the new internals you might put out more hp but not alot more.
And not to be rude but bassed on your origional post you might wanna do a little more research into internal combustion engines. It sounds like you have a basic idea of what you want and how to do it but you might be missing some of the finer points. ie: race valves and new cylinders.
Posted: May 12th, 2006, 9:37 am
by lakersfan1
ninjajim4 wrote:whats the current exchange rate?
I think it's about $.90 cents to a Canadian dollar right now. American dollar sucks now.
