what year did they start having chipped keys
Posted: April 30th, 2006, 10:58 am
by peteuk
I`m on the look out for a immobilser for P reg v6 mx-3 ( mines died).
i`m after one from a breakers yard, question is what year did they start having the chipped keys & immobilser. I know the J reg ones dont have them, if you have say a L reg that does need a chipped key, could you let me know..................
Posted: April 30th, 2006, 3:56 pm
by garfy1981
Mines a M reg, and no chipped key here. Ive got a cobra alarm/immobilizer.
Is there no way you could add a after market imobilizer to override the mazda one??
Ive got 2 massive genuine mazda manuals on the mx-3. ( big fat red ones from ebay ) Ill have a look to see if theres any wiring info ?
Have you checked the online manual ??
On mitsubishi and a renault i had the the immobilizer was built into the ecu, dont know if mazda did the same ??
Posted: May 1st, 2006, 3:54 am
by peteuk
Thanks for the reply mate.
Looks like they only fitted them from 96 onwards.............just my luck.The immobilser is fitted under the centre consul near the ECU.
Theres a shed load of wires attatched to the immobiliser, so bypassing it looks very difficult.
I`m guessing my problem is the thing that reads the chip in the key ( located around the ignition switch).
This cars being a right pain..............
Posted: May 1st, 2006, 1:36 pm
by garfy1981
All cars are a pain in the arse at some point in there life,
all the immobilizer is, is a relay switch which isolates a key part of the ignition, so if you can find the wires that it is switching its just a case of cut and join, ( fingers crossed )
With VW theres a code you can input if you loose your key, by turning ignition on/off in sequence with the code, this deactivates the chip reader, but if such a thing existed i expect mazda would have told you.
I let you know if i find anything.
Posted: May 1st, 2006, 3:44 pm
by peteuk
Yes there is a code. Mazda take the number off the immobilser & that generates a key code on there computer, which they code on your key............the cost £140.
Well its been to mazda & they say its not responding to the code & they have phoned mazda technical support who told them to do a full immobiliser check. The current bill was £180 & any futher work was going to cost £65 ph + parts. Not going to pay anymore to mazda............I hooked it up & towed it home.
Posted: May 2nd, 2006, 1:08 pm
by garfy1981
holy shizzle !!
