"Intermitting" misfire and "power train"
Posted: April 3rd, 2006, 6:18 pm
by MOSES
I was bootin down ther highway today, noticed my CEL came on so i pulled over just for a checksy.
she was idling really rough and low, so i drive it to the shop turn it off, when i turn it back on 5 min later it was idleing fine, but still had the CEL in.
ITs been intermitting all evening, but doesnt shut off.
people get misfring with bad fuel pumps, bad spark plugs, bad wires, but this is intermitting, so, i dont believe its any of these.
Posted: April 4th, 2006, 4:37 am
by kiwi_MX3
My hack car has a intermittant problem, but does'nt list any codes
when pulled,
however id pull the codes from the ecu and see what
comes out,
Posted: April 4th, 2006, 4:22 pm
by MOSES
thats what i meant by "power train"
thats the code that the scanner pulled,
thats all it said.
Posted: April 4th, 2006, 6:33 pm
by slimmyslim1420
MOSES wrote:thats what i meant by "power train"
thats all it said.
Is your car OBD2? If it is OBD1 what did you do to pull codes?
Posted: April 5th, 2006, 6:34 pm
by MOSES
i drove it to the shop, they have a scanner or "code reader"
The scanner came up with "power train".
what the hell is that?>
Posted: April 5th, 2006, 8:01 pm
by hgallegos915
missfiring interminiene = hei you forgot to mention that, also timing, disty of clogged fuel filter. This issue i ahd for over 3 months. I was ready to trow my car away and it ended upo being the hei.. so um obdI or OBDII ?
Posted: April 7th, 2006, 12:00 am
by MOSES
forgot to mention Hei? I dont even have that setup,. im runnin stock here.
I have the year of car where you cannot pull the codes with the cel light using the ten and grnd procedure. I dont know if thats obd1 or 2.
Posted: April 7th, 2006, 1:09 am
by XxantwawnxX
OBD2
