ipod question
- GregoryChristian
ipod question
is it possible to download mp3 files from other music sites and add them to your itunes library
** My MX-3 ** http://www.cardomain.com/ride/360367
- Franko
How do you mean? All I do is just drag all my mp3's from wherever they are and drop them where it says 'library' in the itunes software. OR you can go to File in itunes and just go down to 'add files to library' or 'add folder to library'. It dosent matter where the mp3 is from as long as its an mp3.
- GregoryChristian
thanks....now how do you delete songs from your ipod ?
- Franko
Umm.. I think you can remove them from your library if you want by right clicking and then clicking 'clear' . Other wise.. find the songs you dont want on your ipod in the library list and then just click the little checkbox next to the songname and make it so the song is unchecked. Then just sync up your ipod and it should remove it.
- GregoryChristian
- MX-3 Money
Just so you know, you can delete songs, but itunes won't let you copy them back on to your computer. Yet you can get programs for that.
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
IF YOU HAVE NOT SETUP YOUR IPOD FOR MANUAL SONG TRANSFER DON'T CONNECT IT TO ANYONE ELSE'S COMPUTER OR IT WILL ERASE ALL YOUR SONGS.
Itune's won't let you copy back... the files are in a hidden file on the ipod drive...It's x:\Ipod_Control\Music\... All the files are converted to 4 digit code inside files named F01-Fxx.. You can copy them back just as is.. and then you a program like File Renamer. Which has ID3 tag reading and can rename the files to however you like..Or use any number of programs availible to copy them off with the id3 tag already remade..[/img]
