Body Kit molding
- slimmyslim1420
Body Kit molding
I was wondering the best way to mold the sides and rear. I know fiberglass but should you use anything with it to help, or just fiberglass tape with resin over the top of it? And then bondo on the top?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
- Yoda
I use structural adhesive use in the trucking industry for bonding GRP/ FRP and steel or aluminum together. Something I picked up for the old school hot-rod guys at a show afew years ago. A lot stronger bond than using the more common bondo or polyseter resin techniques use by the sport compact guys.
http://www.proformproducts.com/fr/produ ... ategory=67
- slimmyslim1420
Can that adhesive also mold the parts in or does it just bond them together? The way I want it is with no lines or spaces between parts. That might have been what you were saying I don't know, but it seems like that stuff would be more of a liquid than a putty type mixture.
- fieromx3
if ur going to mold parts id seriously only do the sideskirts and if u get hood scoops or roof scoops
but i would not reccomned doing the front and rear bumpers u never no when u might have to take it off or anything right? the only part i would say mold the rear is with that lip on the stock rear bumper but not the actual bumper its self...
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
- slimmyslim1420
Yea I only plan on doing the side skirts for now, and maybe the rear bumper later. I don't plan on doing the front bumper as I am going turbo and I'm sure I will have it off a lot.
I was gonna mold mine but im lazy
and well it looks ugly when cracked...when done properly it looks awesome..if you use bondo it may crack..fiberglass is better.
-hec
- slimmyslim1420
Will the adhesive you left a link to require any special filler, or just typical bondo? Or someother lightweight filler. This step is just to blend and make the surfaces smooth right? Also the bottle they are selling how much could you get out of it? Like one side skirt, or two, or the two skirts and a rear bumper? What is a good estimate on that?Yoda wrote:This adhesive is thick and can be spread out like filler. You can sand it out but you will want to leave it so that you can spread a skim coat of a light weight filler to blend the surfaces together ando depending on the adhesive you may need a special filler to go over top of it.
