Underdrive pulley's worth it on a KLZE?
Posted: February 19th, 2006, 1:13 pm
by Juans_93_MX3
I have searched and gathered some info, read that it is better not to change the altenator pulley because all that would do is make the altenator work harder
Other than that, changing everything else (Water Pump pulley, Crank pulley, A/C pulley, power steering pump pulley) shouldnt cause a problem to the engine or belt... right? Because I havent found any other info saying that it would.
My question is, is it worth the money to buy underdrive pulleys just to free up some HP?
What if the engine is going to be SuperCharged? Would it still matter?
How about if I just replace the crank pulley?
Posted: February 19th, 2006, 3:33 pm
by Teqnyck
I don't know how much power you will free up, but I do know that for every pound you take off of the engines rotating assembly, it's like taking 30 lbs off of the wheel.
Posted: February 19th, 2006, 6:44 pm
by Rick Johnson
I had one, the power was noticeable. My alternator has been weak for years so it was even worse being underdriven and I noticed my engine was running hotter at stops, so I yanked it.
Re: Underdrive pulley's worth it on a KLZE?
Posted: February 19th, 2006, 7:57 pm
by hppwdn
Juans_93_MX3 wrote:I have searched and gathered some info, read that it is better not to change the altenator pulley because all that would do is make the altenator work harder
Where are you finding pulley sets for a ZE? To my knowledge all that's available are underdrive crank pulleys.
Posted: February 19th, 2006, 8:29 pm
by Juans_93_MX3
Actually I havent.
Nether did the searches I did
Ok, so I see that a U/D pulley for the engine's crank wont do anything bad. A UD pulley on the waterpump might make the car hotter at stops?
Posted: February 19th, 2006, 9:50 pm
by JWMX3
I opted not to get one after reading a billion posts on probetalk, over there its about 50/50 those that say get one and those that say dont....... what it came down to was for the 1 out of 250 guys that have something bad happen to their engine its not worth it, you can make the 3 ft/lbs of torque elsewhere....and if you want weight off the rotating assembly, get a fidanza
i suggest you read the 1 million udp threads on PT and then make up your mind :)
Posted: March 4th, 2006, 10:16 am
by shiftingspeeds
I have the 1.8 and bought the underdrive pulley, but was unaware of the decrease in the belt size. Can anyone who might have completed this mod tell me what belt to use.
Posted: March 4th, 2006, 6:24 pm
by RaverChankoMX3
I have both: UR pulley and Fidanza on my straight neck ZE. I've daily driven the car for nearly 5 months now without a problem...unless you count balding your front tires a "problem" :lol:
Anyway, that's my opinion from someone who's running this setup. High recommended. Especailly, for AXing if you can squeeze in the mods.
The UR pulley:
The flywheel:
the CmIII:
Final product:
Where's waldo B1tc!h!! ...no, seriously.
