Turbo question
Posted: January 1st, 2006, 4:59 pm
by RazorMX-3
I want to use a T3 turbo in my setup. I want a high reving engine (8000rpm) and want to use a turbo which does'n't get out of breath before that. So what trubine housing and trim should I use??? Looking for power around 180-200HP.
Posted: January 1st, 2006, 5:51 pm
by fieromx3
give details like what engine are you wanting to use, how much boost, how much HP you want like at the wheels the more details the better
Posted: January 2nd, 2006, 1:37 am
by BuGS
I have a BP, goes up to 7400, running 212whp using a VF10/vj20 Hybrid @12psi running RICH. What yr car and engine you running?
Posted: January 2nd, 2006, 6:51 am
by RazorMX-3
I have a B6 DOHC. I'd like to start of running with around 9psi, maybe in the future up to around 15psi. I'd like to got to around 180 hp at the wheels. Parts for engine rebuilding are already ordered. Going to balance everything so I can reach the 8000rpm without reliabilty issues, and I want to have a turbo which doesn't get short og breath around 6500-7000 rpm.
Bugs: That vj20 turbo you're using, would it bolt onto a stock B6t exhaust manifold???
Posted: January 2nd, 2006, 11:39 am
by fieromx3
if it dont you van modify the flange
Posted: January 2nd, 2006, 12:04 pm
by RazorMX-3
What turbo would you guys recommend for what I want???
Posted: January 2nd, 2006, 7:30 pm
by n2ogsze
A variation of a t3/t4 hybrid would suit you nicely.
Posted: January 2nd, 2006, 11:21 pm
by BuGS
n2ogsze wrote:A variation of a t3/t4 hybrid would suit you nicely.
No, way too big for what he wants. I would probably go with a T3 with a 50 Trim at the most (Still probably too big). They support up to around 250whp in most applications. So for the 1.6, 200 would be pretty easy. But I would still say just ditch the B6 and swap a BP. Search for author named "Josh" then read up on his B6 setup. With my BP only running around 140whp it was dead even with his BUILT B6 turbo engine.
Posted: January 3rd, 2006, 6:25 am
by RazorMX-3
But that's the problem. Here in the Netherlands the BP is very rare. Almost no mazda was sold here with that engine. I looked into shipping one from the US, but shipping cost are so high that it is not doable for me.
But thanks anyway.
Posted: January 3rd, 2006, 11:10 pm
by BuGS
Hmm, look for a 323 GTX or GTR and steal that engine out of a wrecked car. I know a Couple ppl in the Netherlands with 323's, and they said that they had a couple in junkyards they were stealing parts from, That was more than a year ago and both guys have since moved on to different cars.
Posted: January 4th, 2006, 2:04 am
by Shades
Also to reach 8000rpm's balancing will not help you that much because you're still gonna float the valves... you might wanna look at getting stiffer springs and/or titanium retainers and switching to solid lifters.
Posted: January 10th, 2006, 3:56 pm
by ryanlindenberg
yea you should just go BPT. why do you want to rev your engine to 8000, when you can easily and safely make 180hp with the bpt @ 6000?
Posted: January 10th, 2006, 9:07 pm
by nos92mx3
how much money do you have to spend on a turbo?
A 14 b would get you to 180 hp.
Might as well go with a 16 g though.
