Weird starting problem after DE swap
Posted: December 17th, 2005, 9:40 am
by mx32nerDOTcom
I have to hold my key in the crank position for like....8-20 seconds sometimes to get my car to start...Im not really sure what would cause it, once it starts, it won't idle, i thought maybe the idle was too low, would that cause it not starting right away? any help is appreciated
Posted: December 17th, 2005, 10:04 am
by lakersfan1
Two most common problems immediately after an engine swap:
1) Not enough grounds from the block to the chassis/battery.
2) Open/unused vacuum ports on the intake manifold.
In your case, I'd look for any vacuum nipples on the intake that aren't hooked up.
