Changing the lights behind the dashboard dials?
Posted: November 21st, 2005, 6:13 am
by STAINLESS STEEL
I want to change the normal green lights behind the dash and the ventilation nobs to blue ones. Is it the actual lights that I have to change or the actual dials?
And please don't tell me to get the white racing dials, with the blue lights (don't like them very much), unless the dials are black.
Thanks
Posted: November 21st, 2005, 6:43 am
by Grants
Probably both unfortunately... Have a look at this topic
http://teameunos.com/forums/viewtopic.p ... =dash+blue
Posted: November 21st, 2005, 4:01 pm
by Kokiriwave
no they are bulbs....there are two sizes though..the smaller size is 74....
If you decided to do this make sure you have enough bulbs with spares....just in case...
Posted: November 22nd, 2005, 8:27 am
by ovendenk
there is also a green tint behind the gauge faces. also, the bulbs are clear bulbs, but they have a green filter on them that you can remove. i know because i pulled the filter off and put the bulbs back in and the gauges were STILL green. if you take out the bulbs and shine a flash light through, you'll see what grants and i mean.
Posted: November 22nd, 2005, 8:46 am
by STAINLESS STEEL
So, I have to change the bulbs AND the filter behind the gauges?? Is it easy to do? Where would I be able to get the blue filters or bulbs from?
Thanks
Posted: November 22nd, 2005, 9:19 am
by ovendenk
i think the back of the gauges are painted with this green tint. you'd have to figure out what color when passed through a green filter will give you blue. either that or aftermarket gauges. speedhut.com has great options.
Posted: November 22nd, 2005, 12:47 pm
by STAINLESS STEEL
I know that you mix blue and yellow to make green, so the bulb idea wouldn't work. I'll have to change both.
Thanks
Posted: November 23rd, 2005, 9:41 pm
by FIMotorMX-3
I was a little upset when I took off the green caps on my nice clear bulbs in my dash, come to find out now I just have a lighter shade of green lights..... Thanks Mazda..... All I wanted was white lights instead of green...
Posted: December 28th, 2005, 11:05 am
by FlyVFR
STAINLESS STEEL wrote:I know that you mix blue and yellow to make green, so the bulb idea wouldn't work. I'll have to change both.
Thanks
Plexiglass acrylic sheets come in different colors. I've seen yellow colored sheets available.
:?: Not sure if they are available thin enough to fit in back of the dash.
Was wondering
Posted: January 15th, 2006, 1:10 am
by Chemical
Was wondering how you got on stainless? I too would like to have blue gauges but dont like the white facia on the aftermarket ones. Any one have an old cluster that they can take apart and investigate this? Try the yellow filter and see if it makes blue or remove the green one ?????
