Clutch?
Posted: November 1st, 2005, 8:21 pm
by Bumpysbro
well just got my Cat looked at and it isnt that, i got a huge powerloss and it feels like the clutch has been slipping. like ill have horrible acceleration then bam itll pull alot then set back down when i start out. I got no power in 5th and im at too high of rpms for what i should be. i got 100k on that clutch so i wonder if i should replace it with a stage 1 racing clutch? or would my problems be else where
Posted: November 2nd, 2005, 12:16 am
by StylinMike
When you pin it do the rpm's increase fairly quickly? If so, its most likely a slipping clutch...
Posted: November 2nd, 2005, 1:06 am
by ryanlindenberg
yea if you punch it and the RPMs raise quick while speed goes up slowly you have a bad or misadjusted clutch.
Posted: November 2nd, 2005, 11:08 am
by Bumpysbro
well i know my clutch isnt completely out cuz if i let it idle then put it into third then let off the brake and when im falling back i let off the clutch and it pops so i know it works. but ya my rpms climb but no power basically. were gonna try some other stuff before we buy a new clutch just to make sure....like my car needs to shift wayy too early, and by the time im in fifth i have no power left over and im at 3500 at 60
Posted: November 2nd, 2005, 7:28 pm
by ryanlindenberg
it's your clutch...and if it was "completely out" your car wouldn't move at all. unless you got out and pushed.
Posted: November 4th, 2005, 2:17 pm
by Bumpysbro
ahhh allright, ya its not totally gone but im in need of a new one...is excedy any good? found a performance clutch online but not sure if they got any good reviews. thnx
Posted: November 4th, 2005, 8:10 pm
by ryanlindenberg
i think exedy is pretty much the same as a stock one. if you are looking for performance i would recommend an ACT stage 1.
Posted: November 4th, 2005, 8:12 pm
by Bumpysbro
alright, ill check around see if i can find something thnx
Posted: November 5th, 2005, 12:23 am
by mxprecidia
i got a stage 2 for sale if ur interested.
Posted: November 5th, 2005, 3:07 am
by Bumpysbro
ya thats awesome, how much and is it brand new? if not how many miles on it?
Posted: November 7th, 2005, 3:33 am
by Carmaster2005
Ive had my clutch for about 1 year now. Bought it from South Bend. Stage 1, very very good clutch it can take alot of abuse and it still performs smooth like the stock clutch. Id recommend the to anyone. Good luck
