Loss of mileage
Posted: October 30th, 2005, 11:47 am
by anjin1982
Ever since my sohc flooded (water) about 2 weeks ago,its been getting about 180-200 miles to a tank were as before it was getting almost 300 miles to a tank...any ideas why?...
Posted: October 30th, 2005, 12:00 pm
by Mazda_Power
Some of the electronics may still be damp or you might have warped some of the engines internals...
Posted: October 30th, 2005, 5:29 pm
by anjin1982
oddly enuf the idle problem most of us seem to be having is gone it runs great ,i did the jumper wire to read the ecu and the check engine light didnt light so im assuming everything is fine???
Posted: October 30th, 2005, 6:26 pm
by jimishadow
no internal warp ,,,,ecu is most likely feeding too much fuel,try drying it out with hair dryer.it is on the floor under the radio.
Posted: October 30th, 2005, 7:17 pm
by ryanlindenberg
maybe your o2 sensor got F'ed...if the water go that high. this would put the ECU into "safe mode" and run rich.
Posted: November 5th, 2005, 2:20 pm
by Bumpysbro
my o2 sensor was messed up so i put on a new one, but didnt seem to change anything. how would u take the ECU out of safe mode?
Posted: November 5th, 2005, 2:38 pm
by ariesdude
You can reset the ecu -
disconnect the battery negative cable
press brake pedal for more than 20 seconds
reconnect the battery cable
and the ecu will go back to the factory settings
