SCCA classes and engine swap?
Posted: August 28th, 2005, 6:43 pm
by projectmx
I am doing a bp engine swap and was wondering if this will automatically move me to the street modified class in the SCCA or if i can still be in a lower class and work my way up?
Posted: August 28th, 2005, 11:18 pm
by mazdubber
I don't know how the SCCA works. But when I registered for SOLO 1 in Ontario they had to add ZE'd MX3 to the classification spreadsheet. It's a horspower to weight ratio. I ended up in the same starting class as Integra Type R's.
Posted: August 29th, 2005, 1:15 pm
by Nd4SpdSe
mazdubber wrote: I ended up in the same starting class as Integra Type R's.
Sounds about right....BTW, how is yor Solo 1 season going?
Posted: August 31st, 2005, 12:32 pm
by V8KOMX3
yea you should end up in modified but I don't know specificly what class. and time you do swaps like that you end up in modified
Posted: September 1st, 2005, 7:18 pm
by RaverChankoMX3
For SCCA you'd end up in SM. You're class is HS.
I really like NASA more, however. If you want your NASA classing, just post all of your modifications from stock.
