Rear Hatch- This is a complete rear hatch I will not ship- this is local pick up in SE PA only. It has a nicely faded GS spoiler still on it. Rear defrost worked last winter. Rear wiper still worked last week when I removed it. Still has the window washer nozzle. Third brake light is in there. Wire harness is there with both the male and female ends. I'll even include the hinges if you want them. If you want any of the individual parts (spoiler, wiper motor, etc) let me know cause if it doesn't sell I'll sell the parts. Hatch struts not included-see below $100 obo.
Rear hatch struts- worked fine when removed. Held up the hatch with no problem. $35 obo
Rear window washer reservoir- This is the washer fluid reservoir with the pump and hose attached (the hose was diconnected where it joins the hose for the rear nozzle). I filled it and tested it last weekend before i removed it. It worked then. 30obo
Sunroof - worked fine before removal last weekend. Opens and closes. It had a small leak in the seal but I put a dab of silicone on it and its been fine for 2 years. It comes with all the screws i took out to remove it. I even unbolted the brackets from the body and will include those. Shipping may be a lot its pretty heavy but if anyone's interested I'll get it packed and get a quote. If you need any parts let me know; if i don't sell the whole thing I'll sell you the parts. Best Offer
Map light/sunroof switch- Both lights worked when removed last weekend. Sunroof switch worked when removed last weekend. Includes bracket to mount it to roof. $25 obo
