Page 1 of 2
CAI INSTALL question
Posted: July 9th, 2005, 5:02 pm
by Hoodzy
ok so i was lookin over it prepping to install my integra intake and i noticed 2-3 hoses attatched to the bottom section of the airbox, with the little mitsubishi logo. so i'm gettin rid of the entire airbox right so where do those go?
am i lookin at drilling holes into the CAI an attaching them into that??
if so what part
thanks!!
Posted: July 9th, 2005, 7:00 pm
by solo_ryder
no, just leave those houses hanging, dont drill anything into the CAI.
Posted: July 9th, 2005, 7:41 pm
by jschrauwen
Hoodzy, I've got an idea. Since you've got about 200 posts under your belt, I'm sure you are well versed with the search function. Augment that search with the technical info from the on-line shop manual. Print out a copy of the vaccum layout/diagram and thoroughly go over it...over and over again. With copy in hand and physically looking into the engine bay, trace the relevant parts of that diagam's layout as it pertains to your CAI install. Previous BB member's posts with a plethera of pics, their own car domain sites, the manual and just good old common sense will be more than adequate to get you through this relatively simple mod. I'm sure that after 200 posts you are familiar with the term "spoon fed". Let us know how your CAI turns out.....YOU'LL DO JUST FINE!!!!
Posted: July 9th, 2005, 8:40 pm
by Hoodzy
i love u
Posted: July 9th, 2005, 8:42 pm
by Hoodzy
Hoodzy wrote:i love u
and no i wont do just fine i managed to get the check engine light and all i did was take off a piece of the stock intakea nd put it back haaha
Posted: July 10th, 2005, 11:16 am
by jschrauwen
OK, first, what piece? If you want specific answers you need to provide specific details. I'm going to assume that it's the flex tube between the TB and the VAF. By now you must be quite familiar with the inherent/potential problems with the accordian style flex tube. If not kept completely clean and maintained they will, over time degradate, split, crack to a point that you will get a vaccum leak. Vaccum leaks are a bad thing so check your tube to ensure it's integrity. How do you do that? Good question, couple of ways. Use a small refill bottle for butane lighters that can be released by hand control. While the engine is running spray in patterns around the accordian tubing. If the idle speed picks up (goes higher) than you've found the leak. Conversely, you can use a water bottle/misting spray type and do the same procedure. The results will be a slowing of the idle speed.
[Saw your post in TPS thread] Since you know how to pull codes, did you go to the online manual (page F2-86) and follow the instructions there? Did you disconnect or break the TPS connector by mistake while removing the accordian tubing since it's in close proximity?
Don't get discouraged. We all break and f*ck things up from time to time, even the pro's. Post back after you've gone through some of this stuff and we'll take it from there. You'll get through this.
PS The on-line manual is your friend.
Posted: July 10th, 2005, 3:20 pm
by Hoodzy
yah it was the black tubing, no cracks or anything.
u mean page F2-083 right??
yah i must have done something to the tps, dont know what though ahha
its saying alot is their continuity and increase voltage etc between terminals am i going to need a voltmeter or something to hook into the ECM?
Posted: July 10th, 2005, 6:13 pm
by dewthis
Check your vacum lines, you could have pulled the one loose that goes to the egr. Pull the codes. Check everything that you messed with.
For the record, 200 posts does'nt mean nothing.
Posted: July 11th, 2005, 1:08 am
by Conscript
Welcome to my world Hoodzy, Mine did the same thing when I got my intake on. Let me know when the misfiring starts coupled with the loss of HP starts.
Anyways, make sure you leave the 3 tubes attached to that thing with the DSM logo on it. I retardedly took mine all off and left it that way for awhile and things haven't been the same since.
Posted: July 11th, 2005, 1:39 am
by jschrauwen
I've got the exact same CAI off of ebay also and this is what I have so far.
Posted: July 11th, 2005, 3:41 am
by Chiggles
For those 2-3 hoses that used to be attached to the bottom of the stock airbox... you guys with the Integra CAI say to leave them hanging loose, right? Well, for those of you who have the PRM intake instead, do those hoses connect to this unit or are they still left hanging loose as well???
Posted: July 11th, 2005, 11:19 pm
by Hoodzy
when i took off the black intake hosing
and to check to see wtf was going on with my TPS right were the intake attatches to the engine it is slightly grimey, if i cleaned that would that get rid of my check engine light??
Posted: July 12th, 2005, 6:39 pm
by Gro Harlem
jschrauwen wrote:I've got the exact same CAI off of ebay also and this is what I have so far.
ur mx is white?
clean that engine bay up some y0. Simple green & a toothbrush & some water....scrub it up w/brush and rinse off w/water, will make it looks awexome
& nice intake install, my civic si intake doesn't have as many angled bends as that one
Posted: July 12th, 2005, 10:32 pm
by jschrauwen
Gro Harlem wrote:ur mx is white?
I've been thinking about that ever since I decided to take it off the road for the winters last last year. It looks like shyt because that's the original rustproofing that the original owner put on on day one. That along with undercoating and paint protector was all done before it left the showroom floor. Aside from the lower control arms and a very few small bits in the suspension, there is absolutely no rust on the undercarriage or in the engine bay. But I think your right, if I pull the engine this winter, I'll break out the spray9 and toothbrush and have at it. I thought you would have noticed my new signature by now...I like white....LOL
You know I tried to copy your CAI also. Nothing wrong with following the path of those that went before me.
Posted: July 14th, 2005, 4:54 pm
by mike_moss
So what did you guys do with the vacuum line that goes to the EGR Solenoid Valve?
If I just leave it near the air filter, will this cause me to throw a code?
