remove vics shutters=no low end power??
Ok if removed my vics shutters from my intake manifold when i got my custom intake built!!! No my car seems to lack power in the low rpm's, could the shutters cause this?? If not does anyone know what could??
*Dohc B6!!!!
*Dohc B6!!!!
- atlantamx3
... why did you remove the VICS shutters?
my cardomain site: http://www.cardomain.com/memberpage/793483
Re: remove vics shutters=no low end power??
Joey's mx wrote:... removed my vics shutters from my intake manifold when i got my custom intake built...
ummm, boost it and then its no longer an issue
- atlantamx3
- cjthor
I just welded mine shut to make an easier more fluid and quick flow for the manifold. Of course I am boosted.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
why not weld them on the open postion? It would allow for greater air flow.... anytime your boosted, and you can remove a restriction in the intake manifold, its a good thing.cjthor wrote:I just welded mine shut to make an easier more fluid and quick flow for the manifold. Of course I am boosted.
http://www.clubprotege.com/forum/showpo ... stcount=38
Ryan (bpt323) on clubprotege has proven through modding the VICS and smoothing out the inside of the chamber, you can achieve a smoother powerband, resulting in a few extra hp. I would hate to think what not having the 2nd set of runners is doing to your top end.....
- cjthor
How did he "mod" his system? VICS is different that VIRS correct? I figured that if you welded them closed the runners would be as short as possible and make it a straight shot. Should I have welded them open?D323 wrote:why not weld them on the open postion? It would allow for greater air flow.... anytime your boosted, and you can remove a restriction in the intake manifold, its a good thing.cjthor wrote:I just welded mine shut to make an easier more fluid and quick flow for the manifold. Of course I am boosted.
Jarid Perry
open
I just unplugged the wires to one of the solenoids, which opens the valves and keeps them that way. I have tried running my car with VICs operational and with it wide open, i definately saw a nice gain with them open. I think it also depends on what all you have done to your car. But i saw improvements both N/A and boosted.
Also when open you have more mass to your airflow, best bet would be to use the bottom half of the manifold and make a custom upper half(plenum) the beautiful runners will act similar to that of a velocity stack. You gotta love those huge ports leading into the bottom half of the manifold!!!!
http://www.cardomain.com/ride/1404826
BROKE DOWN POS
BROKE DOWN POS
