wierd idle problems!!!
Joey's mx
Post by Joey's mx »
Ok when I put my car into gear it idles at 2500 rpm...but when it is in neutral it idles at 900 rpm!!! What would be cuasing my car to idle high when it is in gear??
azazel95
Post by azazel95 »
Is it AT or MT? I have a MT and I have a similiar problem only mine idles around 1500rpm in neutral with the clutch out but if I push in the clutch it idles around 500-800rpm.
I know my problem is the TPS because I knocked it out of whack.
Jeff K
Post by Jeff K »
mine will idle weird at first mine is a manual it will some times idle between 1.5-2 but only some times and other times it will almost idle at 0 but than jump back up. :D
