Engine Test
Posted: June 9th, 2005, 10:32 am
by Selecta
Hi there,
Had a quick question regarding motor test. I am going to get a ZE motor this weekend and was asking the shop what sort of tests they do on the engine. And they said they don't do compression test as it's not realiable on a cold motor. Instead they would be doing a leak down test to make sure the motor is good.
Just wanted to get your opinion on this if it's a load of bull or if it's legit. Thanks in advance for your assistance.
Uday
Posted: June 9th, 2005, 10:42 am
by Tunes67
A leak down test is generally more reliable than a normal compression test.. their reasoning about not doing a compression test on a cold engine could be valid. Especially on engines with aluminum heads. Heat causes expansion and aluminum expands quite a bit.. so when the engine is cold, everything would be at its tightest point and a simple compression test might not reveal problems that a leak down test might.
Tunes67
Posted: June 9th, 2005, 10:45 am
by Selecta
that is the same explanation they gave me so it seems they are on the up and up...thanx again
Posted: June 10th, 2005, 2:07 pm
by PATDIESEL
I'd ask them for a copy of the leak down test results. That way if you get the motor, install it, and it is crap you can have another shop do a leak down test and make sure it is not a compression issue. If it fails the test then you have recourse against the seller of the motor.
Posted: June 10th, 2005, 3:01 pm
by Selecta
Oh ya there was no doubt I was going to get everything in writting. Also I told them once it's in and everything I would bring it back in for the compression test regardless and they have no problem with that.
Now all I have to do is get the KL3x ECU and a MAF
BLATANT THREADJACKING
Posted: June 12th, 2005, 12:44 am
by FrankenMazda
Im really sorry about this but .... I cant post in buy/sell.
PATDIESEL, why havent you repponded to my email?
You responded just fine, until you received my $158, 10 days ago.
That has me troubled.
Mixup? Fine, ship my stuff. Respond to my email
chris.dunster@gmail.com.
Posted: June 12th, 2005, 4:53 am
by lakersfan1
Selecta wrote:
Now all I have to do is get ..... a MAF
Why? Don't you own an MX3?
Posted: June 13th, 2005, 11:08 am
by Selecta
I do have a MX3..however I am getting the curved neck intake manifold and with the KL3x ECU would need to change my JE-50 VAF as it won't work with the ECU/Intake combo. At least that is what I have been lead to believe and read thus far.
But if I am mistaken please do let me know.
Posted: June 13th, 2005, 11:15 am
by mxmaz
Selecta wrote:I do have a MX3..however I am getting the curved neck intake manifold and with the KL3x ECU would need to change my JE-50 VAF as it won't work with the ECU/Intake combo. At least that is what I have been lead to believe and read thus far.
no just use the je50 vaf. The kl31 or 36 ecu use a je50. The ecu is actually for a straight neck but works fine using the curved neck just the vris points would be off.
Posted: June 13th, 2005, 11:38 am
by Selecta
really? and what would having the VRIS off really do? Also what does VRIS mean? hehehehehe
