Odd problem with car suddenly stalling out
Posted: May 8th, 2005, 1:13 am
by projectmx
my exhaust broke away from the precat wednessday and next friday i'm getting the exhuast all redone but today suddenly my car has started stalling out is this related to the lack of an exhuast or is this a new problem?
Posted: May 8th, 2005, 10:51 am
by projectmx
also it only does it till the car warms up so like the first 3 or 4 minutes then it seems to do ok
odd problem ?
Posted: May 9th, 2005, 12:06 pm
by ktm_girl82
have you checked your catalytic converter ? it may be clogged it would cause your car to stall out on you ? only a suggestion. . . or fuel filter
Posted: May 9th, 2005, 7:30 pm
by projectmx
i'm 100% sure it isn't the cat cause my exhaust broke off at the flex pipe *see first post* and it isn't the fuel filter cuase i put a new one on around 2 weeks ago... but it could be the lack of a cat/exhaust... that is what i'm hoping... i guess i'll know friday when they put my new exhaust on
Posted: May 10th, 2005, 5:55 pm
by 95_mx-3
My car was doing the EXACT same thing for a couple of weeks about a month ago. I did whole Seafoam and Deep Creep treatment, and it never happened again since. I'm not sure something got cleaned up inside and fixed the problem or not. I bought a can of Deep Creep from O'Reiley's, sprayed a half can to the throttle body/blade and drove around. Next day I used the rest and did the same thing. It's only $5.99 or something like that, so you might want to give it a try. You will see a lot of smoke and it looks like it's cleaning something. I also add a can to the gas tank. Right before oil change, I put it in crank case and drove around too. Never heard a bad thing about Seafoam product, so it won't cause any harm. Let me know if you find anything.
Posted: May 15th, 2005, 10:20 am
by projectmx
when you did this did you spray it just on the butterfly? or did you open it up and spray it inside the throttle body? I finally got the car back from the exhaust shop yesterday and it is still doing it today.. oh by the way got a 2.25" alluminum exhaust from the pre-cat back
