kl31 vs kl36
kl31 vs kl36
Is it proven that the kl31 is really better then the kl36 or should i just save the money and get the 36.
94 green rs
92 black gs project bpt. daily driven bpt in a gs...lovin the boost
- solo_ryder
- Aston Wards
at a guess, i'd say if anything they would open earlier, auto's need more low down power 'n less top end. Beats me why people are so obsessed by KL31's, to the point of using K8 ecu's for months while waiting for a KL31...... my 2c anyway!
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
The VRIS points wouldn't even make a difference. This was on Probetalk not to long ago on how to custom program your VRIS points using MSD Window switches. I'll maybe doing this before I drop the ZE in a month or two.
http://forums.probetalk.com/showthread. ... dow+switch
dude you just completely contradicted yourself, you say they dont make a difference so why dump money into having controllable VRIS points?
Yes the points do make a difference.
No, I meant it wouldn't matter if you had a KL-31 or a KL-36 because you CAN customize the points. The VRIS points are probably the biggest factors in KL-ZE performance.
I happen to check mine and mine is a KL36 i got from Lazzyie, and it works a hellavalot better than the K8 ecu did, but I guess it's a good combo having the KL01 cams
Mx6.com forum search just resulted is people saying that the KL31 is only for manuals, while the KL36 is for automatic and manuals, no mention about vris points
- Aston Wards
- jschrauwen
WRT VRIS Points:Aston Wards wrote:Not ALL KLZE's are auto, just MOST are, hence no KL31 ecu's available
What's the big deal about VRIS points, most of you put intakes on your MX's, apparently that screws them up anyway??!
Aston, are you refering to CAI when you say intakes. If so, I would assume that the Probe chaps also utilize some form of CAI. That being the case, I'm assumimg also that they (Probe guys) are setting the VRIS points to probably overcome/fix/compliment the CAI. They appear quite consistant with their findings as far as regained powerbands and torque with the ability to actually set the openning and closing times on each. I'm quite a novice at this but "Newbie's" attached Probe thread seems quite convincing and for me incites further research into the possibilities.
- Aston Wards
