bpt swap problem
Posted: March 21st, 2005, 8:36 pm
by nickmx3
i swapped a 1995 j-spec bpt gtx engine into my j-spec az3 1995 the fuel pump dosent come on. i didnt use the part of the wireharness that connects to the battery and goes to the fusebox in the engine compartment, i did use the ecu harness. the gtx has abs on it this is wired into the fusebox in the engine compartment if i switch theses fuse boxes will this be a problem
Posted: March 26th, 2005, 10:36 pm
by Franko
Fuel pump relay problem buddy..
Check the relay by your ecu.
I circled mine here..
Posted: March 27th, 2005, 10:02 pm
by nickmx3
i would like to know what engine did u have before u swapped in your bpt was it sohc or dohc and what size 1.5 or 6 and what harness did u use because teh ecu you have in the pic dosent appear to be a gtx ecu
Posted: March 28th, 2005, 7:32 pm
by nickmx3
the relay is fine, i need to know the name fo a site where i can buy a harness that works with the az3 harness and gtx ecu
