Page 1 of 2
WHATS FASTER A STOCK 1.8 GS MX-3 OR A MX-3 WITH A BP SWAP
Posted: March 21st, 2005, 8:28 pm
by mx333
Posted: March 21st, 2005, 8:37 pm
by hgallegos915
do you mean bpt swap or reguloar bp? becasue the k8 is sligly faster than the bp. If its a bpt...then yes its way way WAY faster than a k8. I think even better than klze
Posted: March 21st, 2005, 11:20 pm
by mx333
no i ment bp non turbo they have around the same hp as a k8 but much lighter wouldnt it be faster
Posted: March 22nd, 2005, 12:47 am
by lakersfan1
How you figure it's alot lighter?
Posted: March 22nd, 2005, 12:52 am
by papa roached
K8 is about 130 HP, BP is around 125 and the RS isnt a whole lot lighter than the RS really
Posted: March 22nd, 2005, 7:53 am
by Nd4SpdSe
Isn't the B's cast iron while the K's aluminum?
Posted: March 22nd, 2005, 9:20 am
by lakersfan1
Nd4SpdSe wrote:Isn't the B's cast iron while the K's aluminum?
That's what I thought too.
Posted: March 23rd, 2005, 10:21 pm
by Aston Wards
There's been some weights posted before, while the K8 has an aluminium block, it also has way more crap attached to it
Posted: March 24th, 2005, 3:26 am
by kiwi_MX3
K8 = 123Kgs ( dry no oil or water or accessories or flywheel )
Inlet Mainafold Assy 15kgs
Alternator = 5kgs
P/S Pump Assy = 3kgs
A/C Pump = 6.5kgs
Tensioner Bracket Assy = 1kgs
Flywheel = 7.0kgs (stock no clutch assy)
Now a "stock" cast iron 4 cylinder block bare weights in at
70 kgs from memory....
Matt :welder:
Posted: March 25th, 2005, 12:41 am
by Aston Wards
Cheers Matt, knew there'd be a train-spotter out there!
Posted: March 25th, 2005, 3:13 am
by kiwi_MX3
Hey Aston, you still got the window power switch in the other shell???
Ina few weeks im going to borrow the old mans portable cattle weight
platform and weight the empty shell...
Posted: March 25th, 2005, 9:46 am
by mx333
so what would be faster stock k8 or stock bp swap in a rs the bp is lighter but the k8 has +10hp has anyone raced a stock k8 with their bp swap
Posted: March 25th, 2005, 11:55 am
by hgallegos915
Well I have beaten a manual bp mx3 on my k8.. not sure if that answers any questions... also well the driver has alot to do with it. My car had more acceleration than the other car. This was done a few times. I just love it when the vris solenoids open up... before they open it looked as if he was goping to win, but as soon as they opened booom...he was a bit behind.
Posted: March 25th, 2005, 9:40 pm
by Aston Wards
kiwi_MX3 wrote:Hey Aston, you still got the window power switch in the other shell???
The other shell is goooone, but yeah, i think i kept the window switches, which one/s are you after??
Posted: March 25th, 2005, 10:28 pm
by jschrauwen
I put the spec weights in here; http://www.mx-3.com/phpbb2/viewforum.php?f=1
And you boys down on the farm, put that cattle scale away.. :lol:
