Page 1 of 2
Driver's window hard to roll up; how to fix it?
Posted: January 31st, 2005, 4:56 pm
by mamoo
Hopefully there's a simple fix for this one: the window on the driver's side rolls down okay, but getting it back up takes a lot of work.
Any way I can make it smoother?
Posted: January 31st, 2005, 5:08 pm
by 93SOHC
don't know, but if you find out let me know, I have the same problem I have to give it some help gettin up...Maybe some lube on the track and stuff will help
Posted: January 31st, 2005, 5:36 pm
by hotsiit
HAHA....I've got the same problem also...window rolls down fine...and starts rolling up fine, but as I get closer to the top / fully closed position it gets alot harder....been this way for over the past 4 years....never did anything about it :shrug:
Posted: January 31st, 2005, 6:58 pm
by jaydog5678
Silicone spray will fix it temporarily. You can get it at an autoparts store. Mine has done it for a while too but I really have'nt done anything about it either. For the cause, my guess would be the rubber trim on the door has aged and bemoce brittle. When the window contacts the rubber trim, it slows down dramatically. When the silicone is applied, they roll up like new. 8) (atleast for me)
When the window is down inside the door, spray all the rubber that contacts with the glass.
Posted: January 31st, 2005, 10:04 pm
by phillyMX3mayn
dont know why i never asked this question...lol...has been a problem for 2 yrs.
Posted: January 31st, 2005, 10:29 pm
by Domnknpimp
haha i've had this same problem i notice that when it rains it rolls right up. could be that the water lubricates something on the inside. i'm going to take my door apart one of these days and check it out
Posted: January 31st, 2005, 10:44 pm
by MX-3 Caper
I have the same problem, but I find that it gets worse when the windows are dirty, when clean, they roll up with ease.
That lube sounds like it's worth a shot though, thanks for the tip :D
Posted: January 31st, 2005, 11:51 pm
by mamoo
Funny. Sounds like Broken Windows Anonymous in here.
"Hi, I'm Bob and I've had a screwed-up window for six years ..."
"Hi, Bob!"
Posted: February 1st, 2005, 1:10 am
by 93SOHC
thats gotta be it, my weater stripping and seals are all fudged up cause the previous owner tried to replace them himself. Now they're really messed up. Thanks for the info
Posted: February 1st, 2005, 1:24 am
by David Witherow
its and easy fix the screws that hold your window to the track that makes it go up and down are loose causing it to shift to the front and bind up when you roll the window up......all you have to do is take your door panel off and the palstic underneath and tighten the screws that hold the window to the track.....mine got so bad that it broke the window mechinism and i had to replace it thats how i found out what it was
Posted: February 1st, 2005, 7:56 am
by phillyMX3mayn
if this were the case then why would it go up easily in the rain
Posted: February 2nd, 2005, 11:29 pm
by phillyMX3mayn
damn silicone spray works like a charm no more asking the girlfriend to steer while i use both hands to get my freakin window up and no more ashing in the ashtray...woooohooooo :lol:
Posted: February 3rd, 2005, 1:06 am
by Invisible
phillyMX3mayn wrote:damn silicone spray works like a charm no more asking the girlfriend to steer while i use both hands to get my freakin window up and no more ashing in the ashtray...woooohooooo :lol:
LMFAO!
Anyways, another thing is if the silicon spray doesen't do it for you, there is a long metal bar inside the window, there is lubricant that is already on it, it gets built up in the 1 spot, just take your fingers and push it around. I actually took apart my passengers side power window switch and cleaned the contacts seeing as it woulden't go up, would go down fine ,but not up. So I took apart my drivers side door aswell and fixed my slow window while I was there :welder:
Posted: February 3rd, 2005, 2:21 am
by Josh
phillyMX3mayn wrote:if this were the case then why would it go up easily in the rain
because its lubracating the stripping so its no longer binding. i have the same problem. Mazda should do a recall their are so manny problems with this. i broke my crank off and no have a new crank that resembles a shinny pair of vise grips.
Posted: February 5th, 2005, 12:00 am
by stepchyld
graphite lubricant seems to work quite nicely. it's a fine powder, to my surprise. But it's been good to me so far.
