HEEEEELLLLPPPPPPPPPPPP
Posted: January 25th, 2005, 10:09 am
by Wally
ok my whole car just like went dead but i could still drive it and all .... alll my gages went deae and all and i checked my battery and all ... but when i push the gas it bogs and i think it is my altinator but not possitve please help i need to know thanks wally
Posted: January 25th, 2005, 10:23 am
by BuGS
What year of a car do you have? Also have you checked your Fuse box? You might of just blown a fuse. And it matters what year and when you hit the gas at what rpm if it bogs or not. If i punhc it lower than 2500 it bogs in my 92.
Posted: January 25th, 2005, 11:33 am
by white94mx3
Post alittle more info, what year? SOHC or DOHC? what throttle and at what RPMS does it bog down? Did you check all the fuses under your dash and hood? does it spit and sputter after it bogs down? let me know...
ok
Posted: January 25th, 2005, 1:18 pm
by Wally
it is a 94 and i didnt get a chance to see the fuse box i didnt have any rpms showing at all so ...
wally
Posted: January 25th, 2005, 3:40 pm
by 93SOHC
sounds similar to when my MAFS went out, except the no electrical
Posted: January 25th, 2005, 10:52 pm
by BuGS
I am thinking it is deffinantly a relay or Fuse. THe 94's are all digital. So either a fuse blew or your how gauge cluster is bad. But I would check all the relays and fuses first.
got it
Posted: January 29th, 2005, 2:11 am
by Wally
i found out whait was going on i had a bad belt and i just had to t\ake the other one off to fix the one ...
Posted: January 29th, 2005, 9:56 am
by phillyMX3mayn
what does bog mean?
